Originally Posted By: scoobie
I tried the kerosene cleaning yesterday. Drained oil, which was semi black. Replaced with 1/2 jug ATF, and 1 quart kerosene. I sat in the car and ran it for 8 minutes, idling at 1200 to keep the
oil pressure up and running. then drained it, it came out fairly black. then i poured in the remaining 1/2 jug ATF, with 1 quart of
SL 10w30 from a jug. Ran that for 5 minutes, then drained well. I was kind of black, but not really dirty, I would say more clean than dirty.
Then I refilled with the remaining 10w30 in the jug, and topped up with 5w20. Result: not a single bit of difference noticed when running the engine. Engine ran perfectly well before, still runs perfectly well. This is the Mitsubishi 1.5l.
Conclusion, don't bother with engine cleaners. Probably something gets cleaned out, but there is absolutely no change in the engine performance, and you risk excessive wear from the
thin oil/ very thin oil mix. As long as the engine oil is changed at proper intervals, the engine should be self cleaning, and doesn't need anything more - it can even be harmful, but luckily i seemed to have gotten away with it.
I considered going the full Monty, and doing the diesel trick, where you fill engine to brim with diesel, let sit overnight, crank engine over a few times, then drain. However the thought of diesel fuel rocketing out of the cylinders across the road, dissuaded me.
NO offense, scoobie, but how do you know there was anything to clean to begin with?
