Originally Posted By: HTSS_TR
What are Purolator L24458 equivalents in size, relief valve pressure and threads ? Are these Wix similar in sizes: 51356, 51568 and 51344 ? How about Motorcraft and Bosch, do they have equivalent filter to L24458 ?
Part Number: 51568
UPC Number: 765809515680
Principal Application: Komatsu Equipment, Yanmar Engines
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.072
Outer Diameter Top: 3.234
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 16
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 320
Max Flow Rate: 9-11 GPM
Nominal Micron Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.475 2.173 0.148
Part Number: 51344
UPC Number: 765809513440
Principal Application: Various Equipment w/ Isuzu & Yanmar Engines
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.069
Outer Diameter Top: 3.242
By-Pass Valve Setting-PSI: 8-11
Beta Ratio: 2/20=22/40
Burst Pressure-PSI: 360
Gasket Diameters
Attached 2.490 2.200 0.148
Part Number: 51356
UPC Number: 765809513563
Principal Application: Acura (02-09), Chrysler Imports (92-06), Ford Probe (93-97), Honda (01-09), Infiniti/Nissan (96-09), Mazda (71-00), Mercury Villager (99-00), Mitsubishi (90-09), Saturn (04-07), Outboard Marine Engines, Various HD Equip.
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.402
Outer Diameter Top: 2.685
Beta Ratio: 2/20=6/19
Burst Pressure-PSI: 363
Gasket Diameters
Attached 2.475 2.173 0.233
