This season, the trans on my Ford 2810 tractor is due for a change. It's separate from the rear axle/hydraulic reservoir and is a "CRASH BOX" with no synchros. I'm looking for some expert opinions on using some readily available potential "functional equivalents" I have on my shelves now. The manual calls for the following:
M2C-86B (which appears to be in the ballpark 80W-85 GL4 oil)
M2C-159A/B (which appear to be 10W30 or 10W40 multi-purpose Ag oils)
M2C-134B/C (appears to be 10W30 multi-purpose ag oil)
I do not know what's in there now.
My main question is this: I have gobs of a GL4/GL5 rated 75W90 PAO synthetic gear oil. Any reason why this wouldn't work? I agonize a bit in wondering about cold weather performance. If I knew what was in the trans right now, I could make a prediction. Since it has no synchros, I'm not too worried about shifting performance with a 75W90 syn when warm, but I am when cold.
My second question is this: What about a THF (about a 15W20)? It would shift nicely at all times, but what about wear?
If I had to guess about what was in there now, by the feel and smell, I'd say it was one of the 10W30/10W40 grade multipurpose oils, or THF. If I had to put money on one, it would be THF. It has that "smell" and it has to be below 20F before the shifter gets even remotely stiff. It never gets what I would call "balky."
Opinions? Actual experience?
