Originally Posted By: NJC
Thanks - that looks fairly painless.
I used nLite to make an SP3 disk from my SP0. Worked great.
nLite also allows you to strip out tons of garbage in the Windows distribution that you don't want. For instance, the hundreds of keyboard, language and regional options. You also get the opportunity to remove some of the obnoxious XP "features". Obnoxious being a subjective term.
You can also make the installation hands off by putting in your software key number etc.
A couple of suggestions. Don't try to slipstream in individual MS updates later than SP3, it can confuse the MS update process later.
Don't remove anything you don't understand from the distribution.
Originally Posted By: Mysticgold
If I'm not mistaken, the service pack file itself will allow slipstreaming into your installation files using the /integrate
command.
Even if it does, it doesn't let you strip out reams of unwanted MS extras and make a hands off automated instalation.
