Yes you can, however the plugs on the drives aren't the same so you'll need a 2.5 to 3.5 adapter so that the drive can be connected. These range anywhere from about $5-$20
I swear I have also seen, in that same price range, 2.5" -> USB adapters that run off of the USB buss power. A quick search @ Newegg or somewhere similar should net you a few options.
