Originally Posted By: Big Jim
Originally Posted By: zoomzoom
If you want to get rid of the problem you go to root cause..
Root cause here is inadequate PCV system, allowing oil vapors to get into intake and create deposits on intake valves.
Solution?
Get rid of PCV system, and went your crankcase to the atmosphere!
It is simple and it works great
Isn't ignorance wonderful?
Let's see, before positive crankcase ventilation there were road draft tubes that provided crankcase ventilation above about 25 mph. Engine wear dropped dramatically after PCV systems became common.
Now you want to step so far backward that you don't even use a road draft tube?
I take that any time over intake valve deposits and burning oil vapor in your combustion chamber...
Btw I have a tube
that runs along transmission and down to bottom of the underbody to get the benefit of the drift and to prevent wonderful odors getting into car.
I have run the car like that for over 2 years now, done 3 UOA's and all came back with flying colors:
