When you type in MSDS# 9653 which is listed as the MSDS# for Super Tech full syn 10w-30 on a msds report from 7/7/08 you get this MG03135G MAG 1 10W30 MOTOR OIL 00009653.pdf
Material Safety Data Sheet Revision Date: 2009-01-07 11:03:26
I. PRODUCT AND COMPANY IDENTIFICATION
Product Name: MAG 1 10W30 MOTOR OIL
Product Code: MG03135G
Emergency Phone: (800) 424-9300 (202) 483-7616 (CHEMTREC)
Poison Control Center: (800) 222-1222
Company: Warren Distribution, Inc.
727 S. 13th St.
Omaha, NE 68102
Information Phone: (800) 825-1235 (402) 341-9397
Revision Number: 11
II. COMPOSITION/INFORMATION ON INGREDIENTS
Chemical Name % CAS # OSHA Exposure Limits
Distillates, hydrotreated heavy paraffinic 60 - 90 64742-54-7 No PEL established
Distillates (petroleum), solvent-dewaxed heavy paraffinic 7 - 13 64742-65-0 No PEL established
Components not listed are not physical or health hazards as defined in 29 CFR 1910.1200 (Hazard Communication
Standard).
III. HAZARDS IDENTIFICATION
Immediate (Acute) Health Effects by Route of Exposure:
Inhalation Irritation: Inhalation of vapors (generated at high temperatures only) or oil mist may cause mild
irritation of the nose, throat, and respiratory tract.
Skin Contact: Lubricating oils are generally considered no more than minimally irritating to the skin.
Eye Contact: Lubricating oils are generally considered no more than minimally irritating to the eyes.
May cause slight irritation of the eyes.
Ingestion Irritation: Although this product has a low order of acute oral toxicity, aspiration of minute
amounts into the lungs during ingestion or vomiting may cause mild to severe pulmonary
injury and possibly death.
Ingestion Toxicity: Lubricating oils are generally no more than slightly toxic if swallowed.
Long-Term (Chronic) Health Effects:
Reproductive and
Developmental Toxicity:
No data available to indicate product or any components present at greater than
0.1% may cause birth defects.
Mutagenicity: No data available to indicate product or any components present at greater than
0.1% is mutagenic or genotoxic.
Skin Contact: Prolonged and repeated contact may result in defatting and drying of the skin
that may cause various skin disorders such as dermatitis, folliculitis, or oil acne.
Other adverse effects not expected from brief skin contact.
HMIS Ratings:
Health: 1
Flammability: 1
Reactivity: 0
PPE: B
0 - Least 1 - Slight 2 - Moderate 3 - High 4 - Extreme
IV. FIRST-AID MEASURES
MAG 1 10W30 MOTOR OIL Page 1 of 4
Inhalation: Remove to fresh air. If breathing is difficult, have a trained individual administer oxygen. If
not breathing, give artificial respiration and have a trained individual administer oxygen.
Get medical attention immediately.
Eyes: Flush with water. If irritation occurs, get medical attention. Rest eyes for 30 minutes. If
redness, burning, blurred vision, or swelling occur, transport to nearest medical facility for
additional treatment.
Skin Contact: Remove contaminated clothing and shoes and wipe excess from skin. Flush skin with
water, then wash with soap and water. If irriation occurs, get medical attention. Do not
reuse clothing until cleaned. If redness, swelling, pain, and/or blisters occur, transport to
the nearest medical facility for additional treatment.
Ingestion: Minimal risk of harm if swallowed. Do not induce vomiting. Seek medical attention
immediately. Provide medical care provider with this MSDS.
Notes to Doctor: Aspiration during swallowing or vomiting may severely damage the lungs.
V. FIRE FIGHTING MEASURES
Flammability Summary: Combustible at elevated temperatures
Extinguishing Media: Use alcohol resistant foam, carbon dioxide, or dry chemical when
fighting fires. Water or foam may cause frothing if liquid is burning but
it still may be a useful extinguishing agent if carefully applied to the
surface of the fire. Do Not direct a stream of water into the hot burning
liquid.
Fire and/or Explosion Hazards: Material may be ignited only if preheated to temperatures above the
high flash point, for example in a fire.
Fire Fighting Methods and Protection: Do not enter fire area without proper protection including selfcontained
breathing apparatus and full protective equipment. Use
methods for the surrounding fire.
Hazardous Combustion Products: Carbon dioxide, Carbon monoxide
Flash Point: 233 deg. C, [ 451 deg. F ]
Upper Flammable/Explosive Limit, % in air: 7.0
Lower Flammable/Explosive Limit, % in air: 9.0
VI. ACCIDENTAL RELEASE MEASURES
Personal Precautions and Equipment: No health affects expected from the clean-up of this material if contact
can be avoided. Follow personal protective equipment
recommendations found in Section VIII of this MSDS
Methods for Clean-up: Prevent the spread of any spill to minimize harm to human health and
the environment if safe to do so. Wear complete and proper personal
protective equipment following the recommendation of Section VIII at
a minimum. Dike with suitable absorbent material like granulated clay.
Gather and store in a sealed container pending a waste disposal
evaluation.
VII. HANDLING AND STORAGE
Handling Technical Measures and
Precautions:
Mildly irritating material. Avoid unnecessary exposure.
Storage Technical Measures and
Conditions:
Store in a cool dry ventilated location. Isolate from incompatible
materials and conditions. Keep container(s) closed. Do not expose to
extreme temperatures or flames.
VIII. EXPOSURE CONTROLS/PERSONAL PROTECTION
MAG 1 10W30 MOTOR OIL Page 2 of 4
Engineering Measures: No exposure limits exist for the constituents of this product. No engineering controls
are likely to be required to maintain operator comfort under normal conditions of use.
Respiratory Protection: No respiratory protection required under normal conditions of use.
Respirator Type(s): None required where adequate ventilation is provided. If airborne concentrations are
above the applicable exposure limits, use NIOSH/MSHA approved respiratory
protection.
Eye Protection: Wear safety glasses when handling this product if there is a likelihood of contact with
eyes.
Skin Protection: Not normally considered a skin hazard. Where use can result in skin contact, practice
good personal hygiene. Wash hands and other exposed areas with mild soap and water
before eating, drinking, and when leaving work.
Gloves: Neoprene
Control Parameters:
Chemical Name ACGIH TLV-TWA ACGIH STEL IDLH
Distillates, hydrotreated heavy paraffinic No TLV ND
paraffinic
No TLV ND
OSHA PEL TWA for oil mist is 5mg/m3, ACGIH TLV TWA for oil mist is 5mg/m3, ACGIH STEL for oil mist is
10mg/m3
IX. PHYSICAL AND CHEMICAL PROPERTIES
Physical State: Liquid
pH: ND
Solubility in Water: Insoluble
Evaporation Rate: 0.5-2 (n-Butyl acetate = 1)
Specific Gravity: 0.868
Bulk Density: 7.243
% in air:
7.0
% in air:
9.0
X. STABILITY AND REACTIVITY
Stability: Stable under normal conditions.
Conditions to Avoid: Temperatures above the high flash point of this combustible
material in combination with sparks, open flames, or other
sources of ignition.
Materials to Avoid/Chemical Incompatibility: Strong oxidizing agents
Hazardous Decomposition Products: Carbon monoxide, sulfur oxides, aldehydes, and other
petroleum decomposition products in the case of incomplete
combustion. Oxides of nitrogen, phosphorus, calcium, copper,
magnesium, sodium, and hydrogen sulfide may also be present.
XI. TOXICOLOGICAL INFORMATION
Component Toxicology Data (NIOSH):
Chemical Name CAS Number LD50/LC50
Petroleum distillates, hydrotreated heavy
paraffinic
64742-54-7 Inhalation LC50 Rat: 2.18 mg/L/4H; Oral LD50 Rat:>2000 mg/kg;
Dermal LD50 Rabbit:>2000 mg/kg
MAG 1 10W30 MOTOR OIL Page 3 of 4
Petroleum distillates, solvent dewaxed
heavy paraffinic
64742-65-0 Inhalation LC50 Rat: 2.18 mg/L/4H; Oral LD50 Rat:>5000 mg/kg;
XII. ECOLOGICAL INFORMATION
Overview: Moderate ecological hazard. This product may be dangerous to plants and/or
wildlife.
Mobility: No data
Persistence: No data
Bioaccumulation: No data
Degradability: No data
XIII. DISPOSAL CONSIDERATIONS
Disposal of Packaging: Recycle containers whenever possible.
Disposal Methods: Dispose of according to Federal, State, Local, or Provincial regulations. Recycle
used oil.
XIV. TRANSPORTATION INFORMATION
DOT & IMDG: NOT RESTRICTED
XV. REGULATORY INFORMATION
TSCA Status: All components of this material are on the US TSCA Inventory or are exempt.
NAFTA Tariff Code: 2710.19.0000
Chemical Name CAS # Regulation % Range
Toluene 108-88-3 SARA 313 0.001- 0.01
Toluene 108-88-3 CA Prop 65 - Dev.
toxicity
0.001- 0.01
XVI. ADDITIONAL INFORMATION
Disclaimer: This material safety data sheet and the information it contains is offered to you in good faith as accurate. We have reviewed
any information contained in the data sheet which we have received from outside sources and we believe the information to
be correct, but cannot guarantee its accuracy or completeness. Health and safety precautions in this data sheet may not be
adequate for all individuals and/or situations. It is the user's obligation to evaluate and use this product in a safe manner and
to comply with all applicable laws and regulations. No statement made in this data sheet shall be construed as permission or
recommendation for the use of any product in a manner that might infringe existing patents. No warranty is made, either
expressed or implied.
MAG 1 10W30 MOTOR OIL Page 4 of 4s
