Originally Posted By: tom slick
Originally Posted By: The Critic
Originally Posted By: nthach
I like using Molykote M-77 myself. Honda can't be wrong - most of the time anyway. I've used Sil-Glyde, Mercedes' brake pad paste and Sta-Lube with success too.
Molykote can only be used for metal to metal contact points, such as shims and pad support plates (or clips). You cannot use it for lubricating slide pins as the molykote product is not compatible with rubber.
where did you get the "not compatible with rubber" information?
I remember reading it in some Honda service news bulletin a long time ago. I tried doing a quick google search and was unable to find that in verbatim, but I did find this info regarding brake lube from a bulletin on Recommended Greases and Lubricants:
Honda Caliper Grease 08C30-B0224M 4853958 High-temperature, silicone-based grease used to lubricate caliper slide pins.
Molykote M77 (75-gram jar) 08798-9010 4503793 A high-molybdenum-content paste that polishes more than it lubricates. Use it on the back of brake pads and on brake shims.
http://www.civicforums.com/forums/140-ho...icant-list.html
