Was wondering what you guys are using for sealing up the transmission and rear differential .
Looking at the Permatex site and it can get confusing to say the least.
Wondering if the Permatex right stuff 1 minute gasket maker would be my best choice for both.
Figure the rear differential will be easy to get the sealant applied to and ready for install but will
I have enough time to get the transmission pan in place and bolts torqued down ( site says 5 minutes )
Also curious as to what product you all would suggest to clean the pan and differential covers with
before applying sealant.
Last but not least, what side are you applying the sealant to ?
The trans filter kit comes with a gasket but should I apply sealant on top of gasket, then install pan back on housing or apply sealant then gasket them mate to transmission housing ? want to make this as easy as I can while keeping the gasket in place so all of the holes line up. thanks for your thoughts
