Seems to me since I joined BITOG that you all are mostly "bang-4-the-buck" people. I myself am in many ways too. So since you guys are always hunting for bargins, I wondered if changing oil brands or rotating brands at random was bad?
Just as the old Pennzoil "wax" stories, I have also "heard" it is best to pick a brand and run it for the long run unless you decide to swtich and then switch and run the new brand for the long run, but it is bad to constantly change brands.
Now that I have beeen on here, I doubt this old wive's tale, but fill me in if there is anything that can be said about changing oils all the time, and even changing from dino to syn on occaison just to "test" how the engine will run with different brands & kinds of oil.
I would not plan to switch weights much, but that should probably get a mention to so this thread is comprehensive enough.
