The cam sensor was replaced about 3 years and 10,000 miles ago sand that did not fix the problem at least for very long. Of course the sensor could have gone bad again. That simple fix went for $367 at a dealer. The wiring to the solenoid was fixed/replaced a month ago for $250 by the same dealer. that fix lasted 5miles and 5 minutes before the light came back on.
I don't believe it has ever thrown code 1383. It just throws 1380 and 1381. I don't think the CEL had been off much over the past four years, but as I said before, the engine runs great - it does not stall or hesitate and revs up normally.
So the question is now do we throw another $500 to do the timing belt and flush the solenoid holes, or $850 to do that plus a new solenoid, or give it up as a lost cause and spend $100 for a diagnosis at an official repair facility, hope that their repair estimate is more than $825, don't do any repairs and go for one time, one year non-renewable emissions extension?
I think I got my answer on whether I can switch to light weight synthetic oil and throw in some additive (MMO=Marvel Mystery Oil, correct?).
My question is whether the solenoid can be determined to be either working or defective without taking anything apart and spending a lot of money.
Here is a an extract on checking it which seems to imply that the solenoid can be checked by just tapping into various electrical posts and revving the engine, but if the oil or the timing is (also) a problem it would seem you also may not get the desired electrical readings and still not know fi the solenoid was good or bad:
Code P1380 is strictly related to the electrical circuit of the solenoid, PCM and wiring. If the PCM tries to energize the VCT solenoid and doesn't see any current flow or too much current flow, Code P1380 will set. The normal resistance of the VCT solenoid is 3 to 6 ohms. That resistance should not change by any noticeable amount even with changes in temperature. If the resistance is OK at the PCM connector for the VCT solenoid (measuring from the vehicle power circuit, pin 71 or 97, to the control pin for the solenoid - usually pin 44 or 45), you can also perform an amp draw test on the circuit. With the PCM disconnected, turn the key on. Using a digital ammeter, place the negative lead of the meter on battery negative, and place the positive lead to the control pin for the VCT solenoid. The amp draw should be in the 2 to 4 amp range. Only leave the solenoid grounded long enough to get a reading, preferably no more than one or two seconds. The PCM normally duty cycles it, so leaving it fully grounded for more than a couple of seconds can cause damage to a solenoid that is still in working order.
Here's another test you can do to make sure it is mechanically working: With engine running, using a jumper wire, backprobe the ground side of the VCT solenoid. Then rev the engine up to 2,500 to 3,000 rpm and momentarily ground the VCT solenoid; again, only for one to two seconds. You should hear a noticeable difference in the way the engine runs.
This same test can be performed to help diagnose a Code P1381, which indicates that when the PCM commanded the VCT solenoid to operate and retard the cam timing, it did not see any or enough change. This can be caused by a mechanical problem with the cam gear assembly, a bad VCT solenoid, or a problem with contaminated engine oil. Since the VCT solenoid relies heavily on oil flow to create the force to move the cam gear assembly, anything that causes poor oil flow, such as dirty oil, metal chips or flakes in the oil, can affect how well the VCT solenoid functions.
