I see Temperatures TMPIN0 27C TMPIN1 28C TMPIN2 34C
What is the difference between the three? My CPU fan on low is holding at 34C or close to it. My max CPU is supposed to be 85-90C degrees.
AMD 1800 with squirrel cage Cooler Master fan. If I never even get close to 85C range no matter what I do I should be good to go correct? I have a decent size power supply/fan 100 mm ? A small case fan 80 mm? This is to exhaust hot air from case as well.
I leave the power supply switch on Auto as opposed to Low or High. I don't even know what triggers the control on it? I assume hot air in the power supply?
