Long story short,our snowmachine club's Bombardier 400+ snocat broke through the ice and was half submerged in the water. We pulled it out and changed all the fluids and filters, but after running the snocat about 10 hrs, the ATF Dextron II in the hydrostic drive turned cloudy, not the bright red it should be. We assume there was still water in the system. We have changed the oil and filters out again and hope the problem is solved.
My question is, can we some how get the water out of the oil we drained out? Sitting in a clear container no water has seperated out in 4 days, it still looks cloudy. Hopefully there is a way to save it. It only has about 30 hrs on it and if we have to change it again that will kill our grooming budget.
Thanks for any help you can give me.
