Method for improving the corrosion inhibiting properties of lubricant compositions
"[0026] It has also been discovered that replacing at least part of the mineral oil base oil or polyalpha olefin (PAO) base oil in apparatus lubricating oils, especially aviation piston engine lubricating oil compositions with one or more hydrodewaxate or hydroisomerate base stock(s) and/or base oil(s), GTL material derived base stock(s) and/or base oil(s), or mixtures thereof, preferably GTL base stock(s) and/or base oil(s), maintains the thermal and oxidative stability with sufficient solvency to reduce engine deposits provides good low temperature properties and improves resistance to corrosion. The viscometric properties of the lubricant oil composition are also improved. The lubricant oil composition also provides unexpectedly improved rust protection and has a low sulfur content."
Linky
Linky
