Originally Posted By: CapriRacer
Originally Posted By: The Critic
However, why wouldn't it make sense to have your BEST tires in the rear at all times? I understand that certain parts of the tire will wear faster, hence the recommendation (I've been told) to rotate from side-to-side only on certain tires.
I'm almost thinking you're advocating creating a set where there are "better" and "worse" tires within the set. Why not keep all the tires equally good?
Sorry, I forgot about this thread.
What I meant is that, when we replace two tires, tire manufacturers advocate installing the new tires or the "best" tires on the rear axle. Clearly, there are advantages to this practice as illustrated by the many studies and reviews.
In that case, why isn't it a good practice to always have your best tires on the rear axle? Does that make my question clearer?
