Originally Posted By: Scott P
I have that D-Link in my house wiring closet right now. I only have one computer hooked up to it and it gives me a full gigabit.
Sure it does.
Show me a home computer running a gigabit NIC actually capable of gigabit speed, and then a home switch that will do the same.
Ours does. It takes a lot of work (and quality equipment) to make it happen. But the real secret is the infrastructure pull, connection termination and integrity. A single bend exceeding spec, or laying a run in the wrong location (too near a magnetic field or parallel to a mains line), or a sloppy termination is enough to blow it for the entire LAN. All the TCP tweaking in the world won't fix a sloppy punchdown. Even a shoddy patch jumper can muck it up. I pulled our wire myself (about 1500 feet total), as few contractors were careful enough to do it right with 5e (which was SOTA at that time). Cat 6 is slightly more forgiving, but nothing will survive a staple crush.
Honestly though, unless one is moving a very large video file across storage locations, a 10/100 is just as quick for most activities. Most folks "run" gigabit for bragging rights. But we are just future-proofing more around here, as I do not want to crawl through our split level's attics again anytime soon.
