I bet the 1st one the two whites are the heater, black ground, grey signal.
2nd, blacks are ground, white is +12v for the heater, green signal.
You can heat 'em with a torch and see which wire has voltage, that's your signal.
you can hit 'em with an ohmmeter and the two that are (1/2 ohm?) somewhat resistive are the heater.
