Originally Posted By: GMorg
RP offers some significant limitations in applications. The RP link above states "Please Note: Max ATF is not recommended or an approved warranty replacement for: Ford Type F, Ford Mercon SP, Ford Mercon LV, GM Dexron VI, Mercedes Benz NAG-2, Toyota WS, Volvo 5 Speeed. Max ATF is not for use in any CVT applications or AWD units unless listed above."
How is that significant(list below of what you can use it in replace of)? What they do not recommend it for is a lot less then they recommend it can be used for. I have used Royal Purple and it has worked great for me. I can't compare as I have never used the Red Line though.
Allison C-4, TES-295
Audi G-052-025-A2
BMW LA2634, BMW LT71141
Chrysler ATF+, ATF+2, ATF+2 Type 7176
Chrysler ATF+3, ATF+4
Daimler / Mercedes - Mopar ATF+3, ATF+4
Ford - MERCON V
GM 9986195
GM DEXRON, DEXRON-II, DEXRON-IID
GM / Ford - DEXRON III, MERCON
GM DEXRON-IIIG and H
Honda ATF-Z1 (except in CVT's)
Hyundai SP-II & SP-III
JWS 3309
KIA SP-II & SP-III
MAN 339F
Mercedes Benz 236.x
Mitsubishi - Diamond SP-11, Diamond SP-III
Nissan - DEXRON III
Nissan - Matic-D, Matic-J, Matic-K
Toyota - DEXRON III
Toyota - Type T, Type T-III, Type IV
Voith 1161521 & 1161540
Voith 55.6335.32 (G607)
Voith H55.6336.33 (G1363)
VW TL52162
ZF TE-ML 14B, TE-ML 16L, TE-ML 17C
