I changed the oil in the 2000 Bravada yesterday. Did the once over on all the fluids. I've been loosing about a pint of coolant about every three or four months. No leaking to the garage floor. I figure an internal gasket leak. There were about three different BAR'S LEAKS at AZ. I bought the liquid radiator stop leak in a gray 10oz plastic bottle which says it works on radiators, gaskets, heads, heater cores, blocks,... So cjparks what one of the Bar's Leaks products would you have recommended. I have not put anything in yet. I figured I may wait until it is down a bit again so I can dump it directly into the radiator but I may extract enough coolant to do it now. Any recommendations?
