My '96 Camry 1MZ-FE V-6 has 230,000 miles and consumes about a pint of oil between 5,000 to 6,000 mile changes. Oil used is Mobil 1 10W-40 & filters are OE Toyota. I believe the recommendation of the RX treatment and a new PCV valve is correct. If you're going to use a non-synthetic oil, consider change based on time intervals of appx. 4 months, unless you drive appx. 20K yearly. At that annual mileage, I think you'd be fine with 5K dino intervals. From what I read above, however, I agree with the 3,000 mile oil & filter change on the 1MZ-FE of that age & mileage using non-synthetic.
