Changed the oil in my Ford 4.6, I have been vocal about believing 5W20 is fine for these, but its summertime here in Florida and figure I can give straight Delo 15W40 a try and dump if not happy. I am very open to changing my view if proof is given on anything.
So far no change in gas mileage or power, actually cannot notice any change at all, even when I hit the redline as often as I do. Even when (Florida) cold no noticeable difference. I have a new scanner than gives instant engine load percentages, so am learning what loads this thing runs at most of the time. Will keep updated and see how it continues, I have some Supertech 10W30 and Mobil 5W20 to get rid of and will compare against the Delo to see if the cold load at idle changes any. That would give a good idea of the engine power needed to pump the cold oil. Also I have an oil seperator on my PCV line as these motors are notorious for sucking oil from the cover, will see how that changes as well.
Main thing to figure out is the drain back problems of the 4.6 on the passenger head, I described this before on this site. My is double fold as the PCV is on this side, and the exhaust feed to the EGR is on this side as well.
Another interesting post I just did is in the oil filter section, I learned some new stuff on bypass valves.
