Originally Posted By: FrankN4
FOR ENTERTAINMENT PURPOSES ONLY
I have been trying to follow up on this as best as I could. In searching every search word or string that came to mind, I wound up at a GM truck forum, a Chevrolet truck forum, a Cadillac forum, a Corvette forum, GM Goodwrench, a forum called Edmunds, and a few other places. One of the forums has an actual GM TSB. From that very scant TSB and what everyone is saying, it seems that the 9986115 GM spec has four specifics:
1. Exceptional cold flow properties and fuel conserving. One
reply from an oil company said they did not meet specs
because their 75W-90 had a higher 40C and 100C cSt. It seems
the GM spec axle lube is to axle lube what 5W-20 is to motor
oil.
2. Proprietary friction modifiers for limited slip applications.
3. Low sulphur but phos above 2500 and zinc above 2500. Comments
and opinions seemed to indicate that GM axle did not like
"iron sulfide" I am not chemistry minded enough to know but
I am thinking regular axle lubes actually plate gear teeth
with a very hard iron sulfide coating but this can cause c
corrosion especially if there are copper/bronze components.
4. The GM spec has "special seal conditioners." Opinions seemed
to run toward believing GM may have changed/used a different
seal material than the norm, whatever that is.
Again, this is from searching, listening to opinions, one GM tech person, one scant GM TSB, a response from Eaton, and a response from two oil companies. I do not represent it to be fact, just what many/popular opinion is thinking and why they seem to think that way.
So, all of this taken into consideration what should I put in my 2008 Colorado Z71 differentials?
I would like superior lubrication/performance over OEM fluids and personally consider cost as not an issue but rather relatively cheap insurance. However, I don't want to void my warrantee either.
KG
