I posted on another message board stating I use redline 20w50 in my Harley. He comes back and says he used to/or currently does work for exxon/mobil. His response to my statement:
"Ester based products are chemically produced in a non-refining environment, thus depending on type can be cheaper to produce.
Because of their limited applications and market segment they can be dearer to buy.
The main problem with esters is that they are produced to do a certain job and have little or no tolerance for anything else. By that I mean in an automotive application if there was a problem with an engine (such as excess fuel or water ingress) the oil could not cope and would seperate causing damage to the inner components.
Their inability to be mixed with a mineral product is a major handicap in the automotive world because if you needed to top up with oil you could not mix them. It is also advisable to use a flushing agent when switching between the two products to limit contamination.
Their viscosity range is also limited compared to an advanced PAO based product, meaning they do not have the ability to operate on a very wide range of temperatures reliably.
All oils have their place in the market but some are better at doing a job than others.
The confusion with all this is not what is classed as a "Fully Synthetic" oil but what is classed as a "Semi Synthetic" as only a small amount of additives can classify an oil as such."
I am no oil expert, but I cannot imagine most of this being true. I have done some research on these forums thru previous posts, following a lot of on what Mula has said.
Can anyone shed any light on this?
