MolaKule
Staff member
A Newfie wants a job, but the foreman won't hire him until he passes a little math test.
Here is your first question, the foreman said. "Without using numbers, represent the number 9."
"Without numbers?" The Newfie says? "Da's easy." And proceeds to draw three trees.
"What's this?" the boss asks.
"Have you ain't got no brain? Tree and tree plus tree makes 9" says the Newfie.
"Fair enough," says the boss suspiciously, "Here's your second question. Use the same rules, but this time the number is 99."
The Newfie stares into space for a while, then picks up the picture that he has just drawn and makes a smudge on each tree... "D'ere you go."
The boss scratches his head and says, "How on earth do you get that to represent 99?"
"Each of da trees is dirty now. So, it's dirty-tree, and dirty-tree, plus dirty-tree. Dat makes 99."
The boss is getting worried that he's actually going to have to hire this Newfie , so he says, "All right, last question. Same rules again, but represent the number 100."
The Newfie stares into space some more, then he picks up the picture again and makes a little mark at the base of each tree and says, "Ere you go. One hundred."
The boss looks at the attempt. "You must be nuts if you think that represents a hundred!"
The Newfie leans forward patiently and points to the marks at the base of each tree and whispers, "A little dog come along, see, and poop'd by each tree.
So now .......you got dirty-tree and a turd, dirty-tree and a turd, plus dirty-tree and a turd, which makes ONE HUNDRED!"
The Newfie is the now supervisor of an Aerospace company.
