I've read past posts about Chinese rotors and the consensus seemed to be that, for a daily driver + good braking habits, cheap rotors are not necessarily a bad thing.
I need to do a brake job this spring, so it is either Aimcos at about $20 ea, or Raybestos for $70 ea.
Cost-wise, the $50 I would save per wheel would go towards replacement parts for the suspension so I could basically do an overhaul at each corner of the truck while it is up on the jack.
Thanks.
Thanks.
