Originally Posted By: fsskier
Do you want to tackle question number two:
IS trailer tire testing nearly as complete??
I’m not exactly sure what you are getting at, but I’ll just start typing and hopefully somewhere along the way, I’ll answer your question.
ST tires:
These are tires where the size starts with the letters “ST” – which stands for “Special Trailer” - as opposed to “TR” after the size which are truck like tires which are designed specifically for semi tractor trailers. “TR” tires are typically sized for “Low Platform” trailers and the tire sizes are pretty small, but they have to carry the same loads as full size truck tires.
ST tires are typically used in light trailer applications – campers, car haulers, etc. – and while they are “sized” like passenger car tires, they use more inflation pressure and carry more load,
For example: An ST 205/75R15 Load Range D has a load carrying capacity of 2150 # at 65 psi, where a P205/75R15 Standard Load has a load carrying capacity of 1598# at 35 psi.
Here are some other statistics:
If a P205/75R15 Standard Load tire is used in a light truck or trailer application, the load carrying capacity has to be reduced by 10% to 1453# at 35 psi. For comparison an ST205/75R15 Load Range D (or C or B) has a load carrying capacity of 1480# at 35 psi.
So you may ask why aren’t these numbers exactly the same – after all, the “size” is the same! This gets into the way the load carrying capacity is calculated.
There is a basic formula that was originally introduced in the 1930’s that uses the physical dimensions of a tire (the size of the air chamber) and the inflation pressure, and then uses adjustment factors to account for different uses.
For example, there will be a factor because this is a light truck / trailer application, and another factor because the speed will be limited to 65 mph, and yet another factor because the tire is for usage on paved surfaces, etc.
By comparison, the same formula is used for aircraft tires for the airlines. What is different is that an aircraft tire is operated for a short period of time, but is subjected to very high speeds and huge impact forces – and the adjustment factors take this into account. Plus, weight and physical dimensions have to be small compared to the loads being carried. As a result, aircraft tires are physically small (compared to tires with comparable load carrying capacities) and use very high inflation pressures (up to 350 psi!).
Here’s where the problem comes in – and it is similar to the speed rating problem.
The standard test for tires is done on a 100°F room on a 67” diameter wheel at the rated load and rated inflation pressure at 50 mph for 2 hours (I think! I need to check on this to be sure, but it is something like that!). This has been the standard for decades and has served the industry well.
However, over the years, it has become evident that tires meeting this standard are not sufficient for certain conditions – in particular climates with high ambient temperatures. The problem is once you have introduced the standard, it is problematic to change it. – there is no "Undo" button.
So over time, passenger cars have gradually been using tires with higher than needed load carrying capacities – what we in the tire industry call reserve load. I can document 3 time periods where there were changes in the way tires were sized for passenger cars.
Unfortunately, this gradual up sizing did not take place in pickup trucks (and SUV’s). This was one of the lessons that came out of the Ford / Firestone situation a few years back and if you’ll notice, pickup trucks and SUV’s are now coming with tires that are larger than the minimum needed.
However, this lesson has not been transferred to trailer manufacturers – for number of reasons.
1) There are a lot of trailer manufacturers and getting them all to agree on a standard is difficult, even if they felt the pressure.
2) Most trailer manufacturers do not buy directly from the tire manufacturers, so it is difficult for the tire manufacturer to apply pressure to make this sort of change.
3) Trailer manufacturers are just not as sophisticated as motorized vehicle manufacturers are. They just don’t do much in the way of vehicle dynamics studies. It is those types of studies that result in studies involving the dynamics of tires.
4) The responsibility for tire failures on trailers falls more on the tire manufacturers shoulders than the trailer manufacturer.
5) Because a tire failure rarely injures anyone, the government regulators do not have enough clout to force anyone to do anything about it.
6) ST tires are very price sensitive.
7) Most ST tire manufacturers are not mainstream tire manufacturers.
I’m not sure how much of this is cause and how much is effect. Surely reason #6 is at least partially the cause of #7.
So, yes, there is less testing done on ST tires, but there doesn’t need to be as much. Further, the real problem seems to a number of factors.
