Anyone use this motor oil. I plan on using this stuff with my next oil change on my bmw. I believe its full syn.
Here are the specs
Quality Level
API SL/CF
ACEA A3/B4
Opel GM LL-B-025
Approvals
BMW LL 98
MB-Approval 229.3
VW-Specification 502 00 / 505 00
Product Classification
The product is not classified as
dangerous.
Pento High Performance 5W-40 Typical Data
Unit Result Method
Appearance bright and clear visual
Density at 15 °C kg/m³ 857 DIN EN ISO 12185
Kinematic Viscosity at 100 °C mm²/s 13,8 DIN EN ISO 3104
Kinematic Viscosity at 40 °C mm²/s 86 DIN EN ISO 3104
Viscosity Index 167 DIN ISO 2909
Dynamic Viscosity at -30 °C mPa*s 5900 ASTM D5293
Pour Point °C -36 ISO 3016
Flash Point °C 220 DIN EN ISO
Here are the specs
Quality Level
API SL/CF
ACEA A3/B4
Opel GM LL-B-025
Approvals
BMW LL 98
MB-Approval 229.3
dangerous.
Unit Result Method
