Originally Posted By: ToyotaNSaturn
The way around the whole Cisco VPN problem is to run Windows in a Virtual Machine. Sun's Virtual Box is a small download that's free. Then grab a copy of XP (32 bit version), install & patch it, then run the Cisco VPN software from inside the VPN. Just make sure the Virtual Machine is set to "bridged" networking.
I ran this setup for a long while when using XP64 to connect to work's corporate network.
Yup, that's a good workaround
To the OP:
64-bit OS's will run 32-bit code. Similar to how 32-bit OS's would run 16-bit code.
The problem with things like the Cisco VPN client is that they require a DRIVER, which must be 64-bit.
With the price of Cisco equipment, the fact that they do not do this at that level is ridiculous.
To answer the question:
I run 64-bit Gentoo on this box.
I've installed 64-bit Ubuntu, SUSE and Sabayon (based on Gentoo) on a laptop and for the most part, everything works.
You may (depending on the distro) have wireless issues, depending on which card is in the machine.
You may need to experiment, so I would download a couple of the 64-bit LiveCD's to see which ones better support your hardware.
-Chris
