I took a good look under my Dakota today in preparation for my upcoming Christmas road trip. I saw that on both lower control arms the front control arm bushings are really cracked and split around the outer edges I can see between the frame mounting brackets. Is that an indication that the inside of the bushings are shot too?
I'm stil trying to eliminate a bumpy/somewhat harsh ride problem that developed a few weeks ago. Is it really necessary to remove the entire control arm, wheel, caliper, rotor, shock and spring just to get the control arm out? Or can you just loosen the bolts on it to drop it down and replace the bushings with it still mounted to the steering knuckle?
I can borrow a spring compressor at Autozone for the job if it is necessary. Do you also have to remove the lower ball joint too? My Haynes book says remove it but my Dodge FSM does not mention removing the ball joint. And do you really need a special tool to remove and install the bushings or can they be hammered out of the control arm?
I really need some info on this one guys. I could do it here at home but if it's all that involved I wonder what a tire store would charge for it. I am wondering if I might do better to pay to have this done. But I can't even be sure yet that the bushings are causing this bumpy ride condition. The rest of the lower control arm bushings and the upper bushings all look OK. I don't know enough about it so I really appreciate any help you can offer.
