The Wix web site provides micron ratings and beta ratios for their filters. Here is an example of a common Honda filter:
Part Number: 51334
UPC Number: 765809513341
Principal Application: Acura (88-05), Chevrolet (85-88), Dodge (91-96), Ford (88-96), Honda (72-09), Hyundai (89-09), Isuzu (85-04), Kia (01-09), Mercury (87-91), Mitsubishi (89-98), Subaru (87-09) Atlas-Copco, Case, John Deere, Kobelco, Komatsu, Kubota, Onan, Toro & Yanmar Diesel, Other
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.194
Outer Diameter Top: 3.252
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=22/40
Burst Pressure-PSI: 280
Max Flow Rate: 9-11 GPM
Nominal Micron Rating: 19
How do I interpret this info?
Wix 51334
Nominal rating = 19 microns
Beta Ratio 2/20=22/40
From another website:
http://www.noria.com/learning_center/category_article.asp?articleid=564
I am guessing:
Beta 2/20 = 22/40
means 50% multipass efficiency at 22 microns and 95% multipass efficiency at 40 microns.
This doesn't look very good to me and I am wondering how they can call this a nominal 19 micron filter.
Is my interpretation of the beta ratio correct?
Part Number: 51334
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.194
Wix 51334
I am guessing:
Beta 2/20 = 22/40
