Originally Posted By: xpeteyjtx
Hey, not to hijack your post, but...
How do you guys get your snowblowers to start on the first couple pulls? How many times do you prime it?
I changed the spark plug on ours, and used fairly fresh fuel. I have a hard time believing that oil weight would make that much of a different at 0C-32F. It runs well once it starts though.
1st step is Brand new gas, IE bought TODAY, and not mixed with the rest of what's in the can... September's fuel still has summer requirements then they are quickly relaxed going into winter.
Summer gas has a real low vaporization pressure for smog reasons and just doesn't light off all that well.
How much prime and choke etc is unique to your machine's personality. (Mine for example will start on the first pull, run a bit, then foul out and be harder to restart, despite "perfect timing" fiddling with the choke.) Watch your exhaust for black smoke when you start it, you will probably get some for the first few seconds which means it's rich enough. I wind up doing a row in 1st gear with half choke to warm it up under load before going nuts.
