I had new tires installed on an '05 Toyota Matrix XR (FWD) yesterday. BTW, the tires were Continental ContiPro Contact 91V 205/55R16. They replaced the same tires but 91H. 40k miles was achieved but should have lasted longer if an alignment had been performed many moons ago (it is my sister's car). I was also going to have an alignment performed but no bolts or shims readily available. The actual readings are below. What bolts for the front & shims for the rear should I get? What sources online are available or is the dealership my best bet? Do local auto parts stores typically have these (NAPA, etc.)?
Also, what results do I want for this car? Midpoint of the specified ranges everywhere?
Code:
Front Left Front Right Spec
-1.60 Camber -0.02 -1.32 0.18
2.67 Caster 2.30 2.03 3.53
0.04 Toe -0.24 -0.10 0.10
13.43 SAI 12.22 11.72 13.22
11.83 Included Angle 12.20 10.40 13.40
Front Spec
Cross Camber -1.58 -0.75 0.75
Cross Caster 0.38 -0.75 0.75
Cross SAI 1.21 -0.75 0.75
Total Toe -0.20 -0.20 0.20
Rear Left Rear Right Spec
-2.29 Camber -0.62 -1.95 -0.95
0.28 Toe 0.02 0.00 0.29
Rear Spec
Cross Camber -1.68 -0.50 0.50
Total Toe 0.30 0.00 0.53
Thrust Angle 0.13
Code:
Front Spec
Rear Spec
Thrust Angle 0.13
