My laptop's (Lenovo ThinkPad R60) screen resolution is 1400 x 1050 and it looks GREAT compared to my wife's (older) laptop - IBM ThinkPad R51, which is 1024 x 768 (high color, 60 Hz), which looks non-sharp and fuzzy in comparison.
I went into het graphic properties and went into the graphics properties of the graphic device, and it has options higher than 1024x768 ...for example, 2048x x 1536 high color.
what will happen if I select that higher resolution?
will it look better/sharper or won't the laptop not be able to display it?
I mean, on the graphics properties, 1024x768 is the max. right on the slider....
Thanks..
Thanks..
