Making tacos at home
by Reddy45
07/25/16 12:41 PM
Wiring a new garbage disposal
by Hokiefyd
07/25/16 11:38 AM
Power Steering Fluid
by DWC28
07/25/16 10:07 AM
Troy-Built 4.5hp running problem
by Kestas
07/25/16 09:26 AM
Conventional oil instead of synthetic
by corndogzombie
07/25/16 08:05 AM
kohler courage 15 issues
by tomm22
07/25/16 07:58 AM
Small overlap crash test?
by Huie83
07/25/16 07:39 AM
Top Tier Fuels and Tailpipe deposits
by virginoil
07/25/16 07:20 AM
Honda GX35 question
by dirtydannyd
07/25/16 02:08 AM
Need advices for oil filter inspection
by ST2008
07/25/16 01:45 AM
Supertech- ST3387- Virgin cut open
by FordBroncoVWJeta
07/25/16 01:06 AM
Clean battery with garden hose?
by SavagePatch
07/24/16 11:55 PM
Ken_Clifton, HotDog15, curiousaboutoil, 01CAMRY, corndogzombie
58589 Registered Users
96 registered (Andrei, Al, 182RG, 3Phase, Alfred_B, ABerns, 3 invisible), 1869 Guests and 15 Spiders online.
58589 Members
66 Forums
252230 Topics
#1310758 - 12/13/08 07:06 PM RL 5W30 in 81 Rabbit Diesel 9300 mi
wbhgrace Offline
Loc: Seattle, USA
Redline 5W30 in a 1981 VW Rabbit Diesel (non-turbo). 33K mi on rebuilt engine. Fuel is 100% biodiesel (with an occasional few gallons of petrodiesel in the winter to prevent gelling). Oil has 9300 miles on it with a filter (Mann) change at 5000 mi. A total of 2 quarts of makeup oil were added, including the 1 quart the filter holds. 5 quart sump including filter. Vehicle commutes 12 miles each way daily in Seattle (temps range from about 25F in the winter to about 90F in the summer). Si is kind of high - air filter has 20K mi on it so will be changed soon. I apparently didn't get a soot level reading - maybe I have to ask for that specifically? Any comments on this oil in this application? Thanks for taking a look.
Here are the results from Blackstone:
Aluminum 4
Chromium 3
Iron 33
Copper 12
Lead 6
Tin 3
Molybdenum 753
Nickel 0
Manganese 0
Silver 0
Titanium 0
Potassium 2
Boron 31
Silicon 27
Sodium 23
Calcium 2721
Magnesium 8
Phosphorus 1071
Zinc 1293
Barium 0
SUS Viscosity @ 210F 62.4
cSt Viscosity @ 100C 10.9
Flashpoint 440F
Fuel % <0.5
Antifreeze % 0.0
Water % 0.0
Insolubles % 0.4
TBN 7.4
-Will
#1310771 - 12/13/08 07:34 PM Re: RL 5W30 in 81 Rabbit Diesel 9300 mi [Re: wbhgrace]
LargeCarManX2 Offline
Loc: Up here in the NorthWest
Wow...this is a great combo!
Look for the baseline virgin silicon and take that off the 27...you might just be fine. I think this oil will go 15K and change the Mann at 7.5.
"Success is the ability to go from one failure to another with no loss of enthusiasm."
Sir Winston Churchill
#1310816 - 12/13/08 08:32 PM Re: RL 5W30 in 81 Rabbit Diesel 9300 mi [Re: LargeCarManX2]
This is 5-40:
So you would take your number 27-16 of virgin and this =11
Total miles 0
Miles on oil 0
Date 10/18/2008
OIL Redline
Weight 5w-40
Make up oil VOA
ALUMINUM 0
CHROMIUM 0
IRON 0
COPPER 0
LEAD 0
TIN 0
MOLYBDENUM 3
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 0
BORON 2
SILICON 16
SODIUM 0
CALCIUM 2522
MAGNESIUM 6
PHOSPHORUS 1097
ZINC 1308
BARIUM 0
SUS @ 210F 78.5
cST @100C 15.15
Flashpoint F 440
Fuel % -
Antifreeze % -
Water % 0.0
Insolubles% 0.0
TBN 10.8
#1310946 - 12/13/08 11:42 PM Re: RL 5W30 in 81 Rabbit Diesel 9300 mi [Re: LargeCarManX2]
wbhgrace Offline
Loc: Seattle, USA
Thanks for the suggestion. I found a VOA of RL 5W30 from 2004, and the Si was at 17, so that lines up well with the 16 you found.
-Will
#1312334 - 12/15/08 11:39 AM Re: RL 5W30 in 81 Rabbit Diesel 9300 mi [Re: wbhgrace]
addyguy Offline
Loc: Canada
Looks great - interesting application for RL 5W-30. Insols. might be your limiting factor - even after a filter change, you're at 0.4 at 9k miles. Might only get 12k miles out of a change, but that is pretty good!
2010 Kia Soul 2U - 2.0L I-4, auto, 87k miles.
QSGB 5W-20, NAPA select filter(?)
