2002 GMC Yukon Climate Control Problems
by Kgrant
02/06/16 01:11 AM
Vacuum leak after 3800 intake manifold gasket job
by CaliCarLover
02/06/16 12:17 AM
Pops-a-vent fuel can vent
by 901Memphis
02/05/16 11:08 PM
GM Oil Life Update
by CapitalTruck
02/05/16 10:48 PM
Toyota 2.4L & AWD Ok?
by Nick1994
02/05/16 10:40 PM
0W20 in the US but 5W30 outside US for Mazda
by perryg114
02/05/16 08:58 PM
Thoughts on Delo 10w-30 XLE for gas engines?
by Hal9000
02/05/16 08:48 PM
why would someone want to pay with a phone?
by turtlevette
02/05/16 08:16 PM
The connection was reset problem
by Triple_Se7en
02/05/16 08:14 PM
BIG PROBLEM!
by Avery4
02/05/16 08:03 PM
11,000 miles on a BMW
by BigJohn
02/05/16 07:48 PM
Thoughts on 2007 Nissan Sentra 60K for a used car?
by ToyotaNSaturn
02/05/16 07:20 PM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
27 registered (devarshi84, Abakev, CaliCarLover, chrisri, bbhero, 2 invisible), 476 Guests and 191 Spiders online.
56834 Members
66 Forums
244295 Topics
#1310758 - 12/13/08 07:06 PM RL 5W30 in 81 Rabbit Diesel 9300 mi
wbhgrace Offline
Loc: Seattle, USA
Redline 5W30 in a 1981 VW Rabbit Diesel (non-turbo). 33K mi on rebuilt engine. Fuel is 100% biodiesel (with an occasional few gallons of petrodiesel in the winter to prevent gelling). Oil has 9300 miles on it with a filter (Mann) change at 5000 mi. A total of 2 quarts of makeup oil were added, including the 1 quart the filter holds. 5 quart sump including filter. Vehicle commutes 12 miles each way daily in Seattle (temps range from about 25F in the winter to about 90F in the summer). Si is kind of high - air filter has 20K mi on it so will be changed soon. I apparently didn't get a soot level reading - maybe I have to ask for that specifically? Any comments on this oil in this application? Thanks for taking a look.
Here are the results from Blackstone:
Aluminum 4
Chromium 3
Iron 33
Copper 12
Lead 6
Tin 3
Molybdenum 753
Nickel 0
Manganese 0
Silver 0
Titanium 0
Potassium 2
Boron 31
Silicon 27
Sodium 23
Calcium 2721
Magnesium 8
Phosphorus 1071
Zinc 1293
Barium 0
SUS Viscosity @ 210F 62.4
cSt Viscosity @ 100C 10.9
Flashpoint 440F
Fuel % <0.5
Antifreeze % 0.0
Water % 0.0
Insolubles % 0.4
TBN 7.4
-Will
#1310771 - 12/13/08 07:34 PM Re: RL 5W30 in 81 Rabbit Diesel 9300 mi [Re: wbhgrace]
LargeCarManX2 Offline
Loc: Up here in the NorthWest
Wow...this is a great combo!
Look for the baseline virgin silicon and take that off the 27...you might just be fine. I think this oil will go 15K and change the Mann at 7.5.
"Success is the ability to go from one failure to another with no loss of enthusiasm."
Sir Winston Churchill
#1310816 - 12/13/08 08:32 PM Re: RL 5W30 in 81 Rabbit Diesel 9300 mi [Re: LargeCarManX2]
This is 5-40:
So you would take your number 27-16 of virgin and this =11
Total miles 0
Miles on oil 0
Date 10/18/2008
OIL Redline
Weight 5w-40
Make up oil VOA
ALUMINUM 0
CHROMIUM 0
IRON 0
COPPER 0
LEAD 0
TIN 0
MOLYBDENUM 3
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 0
BORON 2
SILICON 16
SODIUM 0
CALCIUM 2522
MAGNESIUM 6
PHOSPHORUS 1097
ZINC 1308
BARIUM 0
SUS @ 210F 78.5
cST @100C 15.15
Flashpoint F 440
Fuel % -
Antifreeze % -
Water % 0.0
Insolubles% 0.0
TBN 10.8
#1310946 - 12/13/08 11:42 PM Re: RL 5W30 in 81 Rabbit Diesel 9300 mi [Re: LargeCarManX2]
wbhgrace Offline
Loc: Seattle, USA
Thanks for the suggestion. I found a VOA of RL 5W30 from 2004, and the Si was at 17, so that lines up well with the 16 you found.
-Will
#1312334 - 12/15/08 11:39 AM Re: RL 5W30 in 81 Rabbit Diesel 9300 mi [Re: wbhgrace]
addyguy Offline
Loc: Canada
Looks great - interesting application for RL 5W-30. Insols. might be your limiting factor - even after a filter change, you're at 0.4 at 9k miles. Might only get 12k miles out of a change, but that is pretty good!
2003 Mazda Tribute LX V-6, 194k miles.
MM F1 5W-20 conventional + Bardahl B2 additive.
MM MPH2 filter.
