What do you guys think about this: I have a 2007 F250 and the rear axle is a Sterling 10.5"? Full Floater with 3.73 LSD. The axle tag and my owners manual is calling for 75w-140 FULL SYNTHETIC oil plus LSD friction modifier. First off the truck is stock, and I use it as a daily driver. I don't really tow or haul anything with it with much weight. I started thinking that if I put some 75-90 in place of the 75-140 I'd probly save some fuel? Time to change the gear lube in the next few weeks. To go with the thinner gear lube I would put a Finned Aluminum diff cover (capacity will not change) on it to help keep temps down. I can understand why they'd spec 140wt though... 3/4 ton HD truck ment to tow. That's cool and all but i'm not using the truck no wheres near those limits.
