Hey, all,
I'm planning to get back to changing the oil on my car in April, and will buy some jackstands to get some room to work under the car. I've never used 'em before, so I have two questions:
1) The bottle jack I'll use to crank the car up will be placed at the correct jacking point. Where should I place the jackstands so they'll hold the car? Under the frame?
2) I plan to chock the rear tires. Once I'm done refilling, etc., is it safe to flick the engine on while the car is still up on the stands? Or should I drop the big beast first, run it, check for leaks, and then -- if there are any from drain plug or filter -- jack the car back up to reach those spots? Come to think of it, just how high do these things put the car, and will I be able to pour in the new oil with it up -- or must I lower it first?
Thanks in advance!
Thanks in advance!
