Originally Posted By: XS650
Originally Posted By: labman
Start lubing the studs. I have for years and never twisted one off or had a lug nut come loose. I used to use motor oil, but now use anti seize. I also apply it to where the brake drum fits the hub.
I do torque to 80 foot pounds rather than the 100-105 specified.
Studs don't get old, just misused. Yes, you may as well replace all the over stressed ones.
That sounds like a good guess for anti-seized studs.
At least your stud tension is consistent. The people not lubing their studs with varying amount of rust on them are under tensioning the studs at factory torque.
If the studs are that rusty (more than just oxidIization), I replace them.
