Originally Posted By: bmwtechguy
Lubegard is an additive that is intended run continuously with your fluid of choice with the idea that it may improve the quality of that fluid. It does contain bio-derived esters as well as other compounds.
Auto-Rx is intended as a safe cleaner to use in your transmission for 1000-1500 miles to gently clean the metal throughout the unit. It is recommended to do a complete fluid exchange after the cleaning miles have been run. No "rinse" cycle is needed for automatic transmission application. Just go back with your fluid of choice or recommended fluid.
If you have some Lubegard in there with the ARX, just run it longer, like 1500 miles. They are both esters, and it may take a few more miles to clean it completely.
Can the Lubegard Bio engine oil attitive be safely used with A-Rx maint dose?
My brother has been using Lubegard Bio Oil additive for years in his engines, and is very pleased with it. I am trying to convince him to use A-Rx maint dose in his new Ram P/U but he won't stop with the Lubegard Bio. Think he'd use both or just stick with the LG Bio.
Thanks
Frank D
Thanks
Frank D
