I believe their 5w-40/5w-50 formulations contain at least 20% PAO. This minimum level of PAO is normally required to pass the VW TDI, engine sequence test that is part of the ACEA, B4 catagory for TDI diesels.
There is an excellent SAE paper from 2002 that addresses this, called: "Formulation effects in a severe diesel engine passenger car test". The paper is authored by Infinium, which is additive company jointly owned by Royal Dutch Shell and EOM.
This paper clearly shows the superiority of PAO basestocks over Group III's in TDI diesel applications with regards to piston deposits and ring sticking.
Everyone with a VW TDI should read it....
Tooslick
