A good oil change interval(3000-5000) with a quality synthetic oil is all you need to do to keep it running great!
Auto-rx is not needed unless you have a issue with the engine.
The car dose not need longer warm up times, but with a turbo its smart to not shut the motor off when your done driving to let the turbo cool down for about 1 min.
If your going to buy one, its smart to check the cars maintainence records as you would want to do with any car.
I would check the oil fill cap, and take a peek into the fill hole. If you see alot of crud there, you know there might be crud and sludge in the whole motor.
