I have a '94 Grand Am GT w/ ~ 193k miles that is leaking mainly externally but a little internally per UOA (coolant additives only at last OCI). A lot has been soaked up this weekend in my garage by an old refrigerator box so I consider it not driveable. The gaskets were replaced at ~ 113k miles but with only the 2nd iteration kit. I have the newest revision from Fel-Pro. It is the PermaDryPlus gasket kit p/n MS 98004 T which also comes with the black RTV sealant for the ridge where the front & rear of the IM contact the block. I also have coolant, spark plugs, & serpentine belt remover loaner tool. A few questions:
1) The ends of the pushrods should be coated with prelube GM p/n 1052356. What is this lubricant? Is engine oil an acceptable replacement?
2) GM p/n 12345739 is sealant for the LIM bolts. Is Permatex 2A or the black RTV sealant that came with the kit a good replacement?
3) Is it difficult to remove the EGR pipe from the exhaust manifold? Is some sort of "rust off" product necessary? Should PTFE tape be used on the threads when installed? I'll also take this opportunity to check all the EGR passages as the check engine light is on in regards to this area.
4) Does anyone actually relieve fuel system pressure with gage J 34730-1? Is loosening the fuel filler cap enough? I've never used this gage when replacing the inline fuel filter. Of course, I don't always do everything correctly, hence the question.
5) Is it really necessary to remove the right engine mount? I also don't have engine support fixture J 28467-A. Is this a specific tool to replace a wood block & jack?
6) What is a good degreaser for the sealing surfaces? IPA or denatured alcohol?
7) Are new bolts required anywhere assuming that I don't break any? Also, I thought that there were new torque values, but the instructions with gasket kit match the values in the service manual.
The water pump was replaced ~ 177k miles.
I'll also replace the ATF, filter, & transmission cooler lines to hopefully address an ATF leak at the cooler (lower hose must be removed to actually access the lower ATF cooler line).
I may have the alternator tested when out, we'll see.
Pictures will also be taken (to help me get it all back together
