Hi all,
Ok, so as a result of a previous thread some wise guys convinced me to use AMSOIL 75w110 severe gear in my front trans/diff and rear diff/LSD.
I was wondering if it's possible/wise/potentially beneficial to throw a quart of redline shockproof (i.e. lightweight or heavyweight, I'm not sure) into the trans and/or rear diff mixture. After reading up on it, it seems like shockproof has a unique attribute for softening or absorbing some of the "shock" of gears meshing.
Now I read that it should be used in wet sump or splash type settings. I'm not sure how the internals of my system are setup, but I know the infamous "uncle scotty's cocktail" used by many Subaru owners (and now defamed due to excess wear) included Shockproof. My understanding was that the primary culprit for the excess trans wear was the HypoyC used in that cocktail, and that the shockproof was likely innocent.
Anyway, I'm preparing to purchase 4-5 quarts of AMSOIL fluid. I got myself a little hand pump for fluid transferring and a funnel with a 3/8" ID for filling through the trans tube. I need a T70 torx bit, but then I'll be set
Can anyone comment on this one way or another? Also, would it benefit anyone on here to order through you as the AMSOIL sponsor? I'm located in SE PA near west chester.
Joe
P.s. The whole reason for this post is my effort to make the trans/shifting of this vehicle a more pleasant and "fluid" place to work
Joe
