Originally Posted By: kingrob
Originally Posted By: GMBoy
but I warn that it is temperamental and hollowpoints.
Unless you know what you are doing you want to stay away from hollowpoints on the 1911 A1 colts and clones.
Than that makes the gun useless for self-defense. You don't want to use FMJ/ball ammo for self defense for obvious reasons. Me, personally, have never had any issues specific to using hollow points in my 1911's - and I own 6. Truth is, they will jam up using ball ammo too. I love the 1911, but due to the somewhat unreliabiilty I carry a .40 or a .357.
In all fairness the 1911 is probably the single greatest design in auto handgun history. If you use it like it was intended, with the ammunition that it was designed with, then you should
never have it jam on you. If you want a more accurate, less temperamental weapon you should look towards other makes and calibers. If you want a powerful round intended for close range personal defense that you can drop in the sand and still fire, then the 1911 is for you.
The .45 can be used with hollowpoints if you're handy with a sanding stone and know what to file down. It can be made more accurate if you want to sacrifice the loose tolerances that it was purposely given to withstand adverse conditions. I still don't buy the whole "you shouldn't use anything but hollowpoints in a self defense weapon". Let's just say I've had pretty good luck with FMJ and leave it at that.
I hear what you're saying and I agree. My .45's tend to work best with Remington Golden Saber's - which are hollow-points. What I meant by using hollowpoints is not so much the better stopping power aspect but the SAFETY of others around. You should NOT use FMJ/ball ammo as a self defense round because it will go thru your target and possibly hit an innocent bystander. Or imagine shooting an intruder in your bedroom and the bullet rips thru and kills your kid in the next room....hollow points minimize this by dumping their energy in the intended target. FMJ ammo is best left for target practice, in my opinion.
