Originally Posted By: daves66nova
so, out of all these brands, which is the most inexpensive bypass setup?
For what application? The truck we are talking about in this thread is quite different than a typical passenger car...
Its all relative...a $10k rebuild trumps the cost of most bypass filters. Just to put that into perspective...
As for the filters, its all about the same...you might save in initial cost and spend $$ in proprietary elements, or you might spend more up front and have cheap elements (my Gulf Coast for example uses a $1.50 roll of paper towels every 10k miles).
One thing no one pointed out is the fact these can be had on eBay now and again...I bought my GCF for 1/3 of what they cost new from eBay...
IMO, you can't look at cost as heavily as other factors...you want a good filter (one that filters well) and one that is easy to change (bypasses don't work well if they aren't changed, if they are hard to change the owner won't service it as often)...
