All in all, I'm quite pleased with the new CJ4...so I guess I truly believe now that it is as good as the oil companies claim. It was tough to gauge over the last few years with all the skepticism though. 1 Quart added...it was CI4+ (oops).
AFE stage 2 Proguard 7
Only a little Power Service Grey here and there
Truck always driven hard...50/50 city highway
Here goes...
Aluminum 6
Chromium 0
Iron 19
Copper 2
Lead 3
Tin 0
Moly 120
Nickel 0
Manganese 1
Silver 0
Titanium 0
Potassium 9
Boron 327
Silicon 5
Sodium 4
Calcium 1927
Magnesium 312
Phosphorus 1070
Zinc 1379
Barium 0
CST Viscosity @100C 14.28
Flashpoint 445 (nice for CJ4 dino)
Fuel Antifreeze 0
Water 0
Insolubles 0.3%
No TBN taken
No tan
Blackstone's comments:
DEREK: The low temp viscosity read 119.664 at 40ºC. The high-temp viscosity you can read in the
physical data. You ran this oil a lot longer than the last, and iron improved quite a bit. We are not sure what
sorts of changes you've made sine January 2007, but we certainly like how this engine is wearing. Metals
are properly balanced and everything read within the average range for the Cummins 6BT engine. The oil
was in good shape physically, containing no moisture, fuel, or signs of coolant. You could run the oil longer, if you wanted! Nice engine.
Here goes...
Aluminum 6
Chromium 0
Iron 19
Copper 2
Lead 3
Tin 0
Moly 120
Nickel 0
Manganese 1
Silver 0
Titanium 0
Potassium 9
Boron 327
Silicon 5
Sodium 4
Calcium 1927
Magnesium 312
Phosphorus 1070
Zinc 1379
Barium 0
Fuel Antifreeze 0
Water 0
Insolubles 0.3%
No TBN taken
No tan
