Originally Posted By: lpcmidst128
Just push the two links toward each other and it should come loose, takes a bit of effort though. You could also try to grab the center of the powerlink so that the plates can slide off a little easier.
I usually don't remove the chain from the bike to clean it. I just spray a degreaser like Simple Green, scrub with a toothbrush and rinse off.
I figured it out, I had to squeeze to the plates together and simultaneously push the two links toward each other.
I'm going to clean the chain with carb cleaner, then relube with the new Finish Line Teflon-Plus Dry Lube.
Thanks!
