I don't even know where to start, i got many many questions.
Here it goes, I have a 525 tall deck stock truck block BBC. it's set up for nitrous use
specs are as follows:
main bearing clearance .0025 - .0028
rod bearing clearance .0030 - .0032
pump gas compression (93 all day)
4340 dragon slayer crank
eagle H beam rods
Diamond 2618 forged custom pistons
hellfire top ring total seal second ring
solid roller comp endure-x pressure fed roller lifters.
I am going to spray the world at it. 300-550+
we just got it off the engine dyno last week i ran 20-50 rottella T. CJ-4 rating...(recommended by my engine builder) we only made a motor passes on it as i did not have the spray hooked up in time and working.
the oil temp got up to 215-250+- degrees after each pull. Oil pressure at a cold idle was at 70 psi. Hot idle came down to 38+- psi when we got the RPM's upstairs it leveled off around 78-83 psi. this is with a blocked bypass and i run a Pure Power reusable oil filter.
i am looking to run the car in a 10.0 cap bracket race. What oil can i run on when I'm on motor only racing. looking for an oil that will create less windage than the thicker 20-50 but don't know what viscosity i can use? And what should i run when i am going to use the nitrous?? the nitrous thing is new to me so i decided ot go big or go home.
i put the bearing clearances in here so some of the analytical guys and gals can make the right recommendation
i am also wondering about shear and oil breakdown at higher rpms... 6,500-7,500 is the viscosity changing.... (just going off of what Joe Gibbs says on his website.)
http://www.joegibbsracingoil.com/trainingcenter/082106.html
what is Centistokes?
I am not concerned with the price of oil. I see it as a cheep insurance and do not want to skimp.
Sorry for the long post and being new and all, but this seems like a super site
eagle H beam rods
