2011 VW Golf Wagon TDI - Issues
by OVERKILL
22 minutes 11 seconds ago
UOA Goodguy deal
by meborder
48 minutes 51 seconds ago
2016 Ford Fiesta factory oil filter CUT OPEN
by car51
Today at 02:32 PM
RIP Bud Spenser
by Jetronic
Today at 02:19 PM
FRAM XG 9688 unknown miles, CUT OPEN
by car51
Today at 02:19 PM
SPARK PLUG change tips for 5.7L HEMI ??
by SumpChump
Today at 01:45 PM
ITP fuel injectors?
by ChristianReske
Today at 01:18 PM
Interesting article in our local paper today
by Papa Bear
Today at 12:46 PM
mixing gear oil for manual tran
by ntoxicator
Today at 11:04 AM
Transmission shudder/and an honest mechanic
by gman2304
Today at 10:57 AM
M1 0w40, 13,011 miles, 2010 BMW 328i
by Patman
Today at 10:32 AM
VW to pay owners up to $10K...
by Quattro Pete
Today at 10:19 AM
peg, CornbreadMan, JoelB, alostaunau, alanwayne1908
58295 Registered Users
82 registered (69GTX, 60ampfuse, anonobomber, Al, 2015_PSD, aquariuscsm, 8 invisible), 2069 Guests and 12 Spiders online.
58295 Members
66 Forums
250939 Topics
Page 1 of 2 1 2 >
#1268734 - 10/28/08 05:53 PM Cummins 5.9L 10k UOA Rotella Syn
thejessman Offline
Loc: Spokane, WA
Here is my Blackstone analysis with 10k on the oil and 125k on the engine. Planning on keeping this oil in there until UOA says otherwise.
MI/HR on Oil 10,062
MI/HR on Unit 125,015
Make Up Oil Added 3.5 qts
ALUMINUM 1
CHROMIUM 0
IRON 10
COPPER 2
LEAD 0
TIN 0
MOLYBDENUM 0
NICKEL 0
SILVER 0
TITANIUM 0
POTASSIUM 2
BORON 5
SILICON 3
SODIUM 0
CALCIUM 3311
MAGNESIUM 9
PHOSPHORUS 1172
ZINC 1418
BARIUM 0
SUS Viscosity @ 210F 72.6
cSt Viscosity @ 100C 13.64
Flashpoint in F 430
Fuel % <0.5
Antifreeze % 0
Water % 0
Insolubles % 0.2
TBN 7.9
2004 Dodge Cummins 5.9L
Motor Guard bypass oil filter
2-micron fuel filter
K&N Air Filter
Rotella Syn 5W-40 CJ-4
#1268742 - 10/28/08 06:01 PM Re: Cummins 5.9L 10k UOA Rotella Syn [Re: thejessman]
Steve S Offline
Loc: East of IGO
Seems about good as it can get.
Why do people post I want the best for my car,,, When there isn't anything that is the best on the car to begin with.
#1268818 - 10/28/08 07:31 PM Re: Cummins 5.9L 10k UOA Rotella Syn [Re: Steve S]
Camu Mahubah Offline
Loc: the Sandhills of Nebraska
Yep. Surprised me how good. Don't think I'd go past 15k though.
#1268863 - 10/28/08 08:17 PM Re: Cummins 5.9L 10k UOA Rotella Syn [Re: Camu Mahubah]
chevrofreak Offline
Loc: Billings, MT
Awesome.
You know, this Rotella synthetic seems to be outstanding oil. I've mixed a single quart in with some other oil in 2 cars now and it stopped the startup rattle in both of them.
I <3 Red Line oil
#1268939 - 10/28/08 09:54 PM Re: Cummins 5.9L 10k UOA Rotella Syn [Re: chevrofreak]
JAG Offline
Loc: Fredericksburg, VA
What's up with the 3.5 qts. of make-up oil?
#1268953 - 10/28/08 10:22 PM Re: Cummins 5.9L 10k UOA Rotella Syn [Re: JAG]
genynnc Offline
Loc: OR
CI-4+ huh? No CJ-4 in those make up quarts right? Gotta get me some of that CI-4+ for the old SBC! Thanks for the post but I'm with JAG what's with the near extra gallon in make up all about?
03 Dodge Ram 1500 5.7= Kendal GT1 5w30, 55 Chevrolet 327/ Muncie= Valvoline VR1 10w30, 67 Chevelle Malibu 283= Quaker State Defy 5w-30
#1269068 - 10/29/08 05:40 AM Re: Cummins 5.9L 10k UOA Rotella Syn [Re: genynnc]
dnewton3 Offline
Loc: Indianapolis, IN
Outstanding report. Simply awesome. Let's not forget, though, that the OilGuard has a lot of credit due here. Keeping ANY oil clean with bypass systems is the key to fluid longevity. The bypass deserves as much praise as the RTS. Together, they are a fantastic team, as evidenced here.
I'd keeping running this until the TBN gets low. I know that Blackstone says 1.0 is low, but I'd buffer that just a bit at maybe 2.0 or 2.5?
Don't see why, at this point, 15k miles wouldn't be doable. Obviously if contamination would become a concern, then that would change the implications. But presuming all stays in the same shape, you should be able to easily hit 15k. With "synthetic" and bypass, I suspect you can safely go well past 15k miles, but at that point UOAs become a must, on a regular basis. UOA's cost a bit, but the info gained can outweigh the "cost" involved at times.
Also agree that nearly a gallon of oil for make up is quite a bit for 10k miles. Depends on the use factor, though. If you're towing or otherwise working the engine hard, that would explain it. Or, are you changing the bypass filter often, and having to make up the fluid?
Regardless of where the oil is going, the engine itself seems to be wearing very well.
Edited by dnewton3 (10/30/08 04:53 AM)
Conventionals vs. Synthetics isn't about which is "better"; it's about which lasts longer, while assuring safe operation, in relation to cost. Any product can be over or under utilized. The same applies to filters.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
#1269206 - 10/29/08 10:32 AM Re: Cummins 5.9L 10k UOA Rotella Syn [Re: dnewton3]
thejessman Offline
Loc: Spokane, WA
Yeah its CI-4+. I stocked up at Walmart earlier this year so I'm set for a while.
The 3.5 quarts of make-up oil are because I'm using a Motor Guard bypass filter. I change it out every 3K and add a little over 1 qt. of make-up oil to replace what came out with the filter. Its definitely not using all that oil!!
With this system I'm doubtful I'll ever have to drain the oil since I effectively replace a 1/3 of it every 10K miles. That should be enough to keep the TBN and additives up where they should be. I'm going to keep doing UOA so I can keep an eye on it though.
Edited by thejessman (10/29/08 10:33 AM)
K&N Air Filter
#1269211 - 10/29/08 10:38 AM Re: Cummins 5.9L 10k UOA Rotella Syn [Re: Camu Mahubah]
Steve S Offline
Loc: East of IGO
Why the TBE is 7.9 The wear numbers are low. via uoa results the oil could go way longer. That is the advantage of syn oil and bypass filter. I would say the oil could run the 10,000 oil change interval with out the bypass filter.in fact any current dino could go 10,000 miles with out a bypass filter. Anyway syn oil and a bypass filter is about extending the oil change intervals ansdif you are running a bypass filter and syn oil and not taking advantage of the reason for what they are for then it is a waste of money.
#1269462 - 10/29/08 04:38 PM Re: Cummins 5.9L 10k UOA Rotella Syn [Re: dnewton3]
D-Roc Offline
Loc: quelque part
As usual, dnewton3 echoed my sentiments almost a tee... \:\!
#1269641 - 10/29/08 08:34 PM Re: Cummins 5.9L 10k UOA Rotella Syn [Re: D-Roc]
Steelhead Offline
Loc: Washington
great numbers with low wear and good viscosity
Shell does this with very low boron and NO moly.
says something for the base stock
any towing? stock engine, hp and torque?
silicon is way down there for a diesel air sucking turbo. what air filter?
do you attribute the low silicon to the bypass?
3.5 qts make up oil for bypass change
that works out to about a 35k miles OCI
gonna put Shell out of business
convinced me to put a bypass filter on my Cummins 5.9 GenIII
Edited by Steelhead (10/29/08 08:42 PM)
#1269687 - 10/29/08 09:36 PM Re: Cummins 5.9L 10k UOA Rotella Syn [Re: Steelhead]
thejessman Offline
Loc: Spokane, WA
The engine is pretty much all stock, only thing I've done is put on an Edge Mileage Max Module (which I've been pretty pleased with BTW), and the oil and coolant bypass filters. I just recently put on a 2-micron fuel filter after hearing about people loosing injectors and pumps to dirty fuel.
My air filter is a K&N. I've been a little apprehensive about the K&N as right after I put it on I found out with those filters air flow = great but filtering = not so great. \:\( However it looks like its doing a pretty fine job from my low silicon levels.
I haven't done much towing with my truck so far. Right now its the only vehicle I've got with more than two wheels so mostly it just get used as a daily driver.
I'm not sure if the bypass filter is helping keep the silicon done but I'm sure it not hurting it.
K&N Air Filter
#1269699 - 10/29/08 09:55 PM Re: Cummins 5.9L 10k UOA Rotella Syn [Re: thejessman]
thejessman Offline
Loc: Spokane, WA
Actually my mileage module is the Quadzilla one. I don't know why I was thinking it was the Edge one.
K&N Air Filter
#1274673 - 11/04/08 09:11 PM Re: Cummins 5.9L 10k UOA Rotella Syn [Re: thejessman]
Steve S Offline
Loc: East of IGO
I would dump the [email protected] air filter . You have a real engine use a real engine filter. You engine unless modified gets all the air it needs with the oem filter.
#1276395 - 11/06/08 09:55 PM Re: Cummins 5.9L 10k UOA Rotella Syn [Re: Steve S]
thejessman Offline
Loc: Spokane, WA
Yeah I know the K&N is probably not the best thing as far as filtration goes. However its what I got and its paid for so I'm probably going to stick with it for a while. My truck pretty much gets only freeway miles so dust shouldn't be too much of an issue. I'm going to keep an eye on my silicon levels and as long as they stay low I'll stick with the K&N.
K&N Air Filter
Page 1 of 2 1 2 >
