Originally Posted By: RI_RS4
Biosyn should perform similarly to the way it does in the Audi FSI V8. The 1st change will preform some cleaning, but if 1-2 quarts are drained and refreshed, you should be able to push the OCI out. After that, you should see much longer OCI's. I routinely run 10K.
wow... 10k, on your engine... the BDY engine (and the second generation of 2.0T motors) says 10,000 mle OCI's from the factory...
especially when you get on the 'tex some of the a$$hats tell you either get VW502.00 oil or your an idiot--- and it's the same idiots that don't realize the VW502.00 is inadequate in turbo FSI motors. They have no real proof, that 502.00 is adequate, only because VW and Audi says so, that's enough proof for them.
